Because after drilling 30 or so holes in granite with 14 mm carbite tipped drill bit specially designed for granite, the clutch in this drill failed.Tools with serviceable brushes I can recommend - but I can't recall ever seeing SDS drills with "serviceable clutches". Why do you need that?
Drill bit I am using is Irwin Speedhammer Plus 14.0 mm x 210 mm.What diameter and length of holes are you going to be drilling?
Blup
Erbauer sort of says it for me. If you look at any of the professional 3kg or heavier SDS+ or SDS Max drills (e.g. Milwaukee PLH-32XE, etc) you'll find that they come with easily accessible brushes, however the clutches are not that readily accessible. These drills tend to need 110 volt, though, as they are designed for trade use (and come with an appropriate price tag). I think for the task you are looking at I'd possibly consider a pneumatic drill if you can find one, and assuming you have access to a large enough compressorBecause after drilling 30 or so holes in granite with 14 mm carbite tipped drill bit specially designed for granite, the clutch in this drill failed.
Must have become overly worn after the bit got stuck a few times.
https://www.screwfix.com/p/erbauer-...ds-plus-drill-220-240v/232fv?_requestid=45542
Have you considered a better quality 2 kg sds drill like the Makita which comes with a three year warranty?
And maybe use a series of smaller sds bits building up to the full size you are drilling.
https://www.amazon.co.uk/Makita-HR2...=2025&creative=165953&creativeASIN=B01636IZ0G
Blup
Thanks. I've got those and another set too.
