looking for replacement ideal heat exchanger 076663
10 Nov 2014
London
Does anyone know where to get hold of replacement heat exchanger part no. 076663? Thank you. Kind regards.
IDEAL H/EXCH [Part# 076663]
Fits: WLX RS40,WLX CF40,WLX CF50,WLX CF60,WLX CF45P,CONCORD WRS 240A,CONCORD WRS 255A
You'll struggle to get a new one. These heat exchangers have 4 O rings that can easily be replaced to cure leaks in that area. Done loads in my time. What problem do you have? Old boiler, but simple and reliable.
Four 002921 'O' rings have arrived complete with high tac silicone grease and high temp silicone sealant. Will take the two cast iron segments apart, grease the new 'O' rings and replace. Will use sealant on the two vertical mating surfaces of the two segments so that the heat only goes upwards. Thank you for your help. Kind regards.
