Looking for smoke alarm with 120mm+ diameter base
23 Sep 2010
Moved into a property that has a papered hallway and landing ceiling. Stuck to the papered ceiling are two old smoke detector bases - measuring 120mm diameter.
I've tried to remove a base but gave up as its clear it will result in some/all of the paper being damaged/removed.
Plan B is to try and find two battery powered smoke alarms with bases that cover the area. Tried a few shops but they only seem to stock smaller sectors.
Any ideas? Need to have a base larger than 120mm.
Thanks for reading
You can buy MDF or ply circles from craft shops/ebay etc in almost any size example
If you are putting in new smoke detectors I think they now have to be mains and interlinked to comply with Building Regs?
