Hey everyone, just looking for some advice/thoughts.
I recently knocked down a brick dividing wall to merge the kitchen/dining room. I made sure it wasn't load bearing to begin with and checked the ceiling beams all ran parallel to the wall.
Just to be safe I left the ends in at either side and now I'm here to ask if you think its safe to remove these also.
In the below image one of the ceiling beams runs along top of the wall but it doesn't appear to actually be supported by the wall itself as it continues through onto the central wall between the Diner/Living room, every other beam in the ceiling before this has no support and spans the same length afterall.
The below image is taken from the other side in what was the kitchen. The ceiling beams in here sit on the wall but not the part which I am looking to remove.
The below image is side on, where the wall i have removes originally was
Below are the bricks on the other side I left that I want to remove, am I right in thinking these can be cut off leaving the wall flush? My only thought is might they be providing lateral support? it seems there used to be a doorway here which is the reason for them not being staggered.
My second question is regarding adding a lintel into a fireplace/chimney stack to provide a nice area for a range cooker.
I'm wondering can the lintel span the whole length of the wall edge to edge or will it want some bricks leaving in either side...
Thanks everyone any help or feedback is greatly appreciated.
