Looking to replace ceiling extractor fan.
31 Oct 2014
Yorkshire
Hope you can assist, I need to change an extractor fan that is currently fitted in the bathroom.
I want to replace in exactly the same position (i.e. ceiling) and connect to the same ducting that connects to an outside wall.
Can any expert recommend a direct replacement, I can't locate this on the web. The current model is :
"Greenwood Air Management AX 100 CM-B 230v 50Hz 15w)
...or can I choose any main 4" fan?
The current Greenwood range is the AXS.
http://www.greenwood.co.uk/product/32/503/axial-extractor-fan-range.html
These are widely available with different models depending on options you need: timer, humidity etc etc
Most 100mm fans ail do the job providing they are designed for ceiling mounting in bathrooms.
Do remember that (like some women) performance is linked to the price you pay ;)
Apologies to the gals...
