hi all
looking for a bit of advice ! i want to install halogen downlight in my kitchen, i have a normal light pendant at the min, was going to wire the halogen in the daisy chain method. i have taken the the cover off the celling rose and discovered it is a loop system,
i have a live , neutral and 2 wires coming into the rose for the loop 1 from the live 1 from the neutral . on the celing rose the loop wires have there own block to go into ,but on the halogen i only have a small block within a case with connections for the live and neutral, my thinking was to put the neutral and its loop into the neutral position on the first down light and the same for the live is this correct or more impotantly safe before i start or do i need a junction box
any advice would be great
thanks
thanks
