Loop Wiring - Replacing a Celing rose
15 Mar 2004
I am replacing an old celing rose which is fitted in a loop system with a new light fitting which has only the Live Neutral and earth connection and no loop connectors like the old celing rose. They suggest that you use a flex block connector for the loop wires, is it a 5amp block connector strip I want?
Is it a 5amp lighting circuit you've got?
I'd always use 15A terminals for this job because it's a lot easier getting all the conductors in and the 5A ones often have nasty hybrid screw heads.
Will Do, Thank you Dingbat ! ! !
