Loose CH pex pipes between joists... problem?
15 Jul 2018
I've ran my CH flow and return but can only clip them to the joists every 1-1.5m as I ran the pipes in the middle of the noggings and i ant flex them enough to touch the joist to clip them to it.
Is this a problem? I know with copper pipes which are loose will often bang but seeing as the pipes are plastic and covered in insulation, will I get any problems?
They should be fine
