On our new house (new to us anyway) we have started stripping back the old wallpaper - it is coming away well but so is some of the plaster and the sand/cement behind.
I am tempted to get a plasterer to fix it up and make it a nice flat paintable surface however money is a little tight with a number of other projects to do.
My main issue is that the layer of sand cement that was applied to the bricks (1930s house) has come away in some areas and on others where it looks fine there is a tapping noise when you knock the wall with your knuckle suggesting it is not properly bonded to the bricks.
I guess ideally you pull down the entire plaster finish and the sand/cement down and go back to brick but I really don't want to go down that route due to the expense at this stage.
The sand/cement certainly won't go anywhere (of course I would never had known if we hadn't started stripping the paper.
Could I get away with a skim and hope the cemented parts do not deteriorate too much after and cause cracking? Are there any particular products to try?
It is on quite a large area (hall way, stairs and landing). For the area where the cement has come away completely I will fill it with some mortar and finish with multi purpose plaster.
Many thanks for any advice.
Jack
Photos (I will get a photo of where it has gone back to brick later today):
Jack
