I've spent the day understairs glueing and screwing as per the https://www.diynot.com/diy/threads/screw-size-squeaky-stairs.592566/ and found the stringer flexes as someone walks up the stairs.
It appears the stringer was attached to the wall with large cut nails. The plaster behind them has crumbled over the past century. So there's stringer, 1 inch ish gap, wall. The nails are loose and there's movement.
What's the best way to fix?
Torn between screwing some 2x4 underneath for it to rest on, or masonry screws through the stringer.
Neither solution is ideal. There's no consistent smooth end on the stringer for the 2x4 to butt up against (it looks like there was a rebate for a tongue) that's broken in places, so I'd need to pack and wedge.
For the masonry screws, I'd need to (I think) pack between the stringer and wall. Messy and lack tools to cut the correct depth.
Suggestions welcome.
@JobAndKnock all day I could hear your words taunting me that it would, in the long run, be easier to replace the lot.
