We have had 2 boiler engineers out to fix our Potterton Puma 80e which has been working intermittently. It is still failing to work sometimes and having taken the cover off and had a quick look, we have realised that the cause of our problems is a loose wire on the PCB (if you move the wires around a bit there is a spark behind the panel and the mains light comes on, which it was failing to do, and the system fires up).
All I want to know is, what kind of job will be required to fix/replace this wire? eg will we need a new PCB/new wire/etc.
I want to get more information so that when we get someone else in to fix it, I'll know if what they are saying is accurate!
