Hi
I have a 2 year old (non-combi) boiler in a 50 yr old house with concrete floors downstairs. The system had a leak in one of the heating system pipes feeding the downstairs rads (under the slab) which was diagnosed and fixed by trace and access guys and the system tested clear of leaks earlier this year - since then, over summer, the pressure has been rock steady at 1 bar with the heating off, but hot water on.
Now that the heating is back on again, the pressure is dropping by 0.3-0.7 bar a day (depending how long it's been on for) and needs constantly topping up. Someone has suggested that the boiler might be damaged and is leaking water internally out of the condensation drain and having checked it is indeed passing a lot of water out of that pipe (constant flow of drips when it's running). I asked the engineer who installed/services the boiler and he said it's normal, but the pipes are apparently leak free. So I'm stuck.
The boiler is a Viessmann Vitodens 100.
Any suggestions on how to prove whether the loss is due to the boiler or the rad pipework without dismantling things/capping pipes etc?
Is the fact that pressure only drops when the heating is on but not when the hot water is on relevant?
Is there something I can tell the engineer to do to the boiler over and above a simple annual service that would prove/disprove a boiler fault?
Any pointers would be gratefully received.
