Can anyone please advise on this? I have a flat which has just been extensively modernised, since when the hot water flow at the kitchen tap has reduced to a trickle.
It is an upper floor flat and the (unpressurised) water supply consists of a cold water tank with ballcock valve, immediately above the hot water cylinder. These sit on the floor and so the head of water is not great, but before conversion the flow was acceptable.
However, now that a modern s/s sink with mixer tap has been fitted, the flow is inadequate. There is only one hole in the sink and so two separate taps are not an option. A plumber suggested that the small-bore fittings for the two flexible hoses into the bottom of the taps, combined with new isolating valves which may not be full-bore, could be responsible.
Can anyone suggest a type of mixer tap which might give a greater flow, or any other solution other than (a) fitting a new sink unit with two holes, or (b) fitting an automatic pump on the hot supply coming from the cylinder, neither of which is really practical for various reasons?
Many thanks,
Alec.
Many thanks,
Alec.
