Hi Guys,
Recently had house re-wired and current situation is that in two rooms, I have 3 cables coming out of the wall for sky. Not the prettiest, but the builders walked out on the job so thats how it was left.
Anyway, two of the cables are connected to the sky HD box, with one of them lose to connect the the RF Out point. This then goes to the loft ready to plug into an amp to feed the other rooms. (Other rooms have the normal areal point on the wall ready to be plugged in.)
The second room has the same set up except its a sky plus box, rather than an HD box.
OK, so firstly I am annoyed that they didn't use the two lines of cable within one sleave as that would have meant I could have had both of the sky feeds in each roomn giving a choice of which one to look at, but nothing to be done about that I guess !
So the question I have, currently the two wires for the sky signal go straight from the lnb into the back of the sky box without any connections.
The problem with this is that the wires, as I say, just stick out of the wall...
Now, I can get a faceplate made up with the three sockets (would this be F-connector type) so it looks cleaner and neater on the wall, but I wan to check that this will not result in a huge loss of sinal and quality.
Apologies if this has been answered elsewhere !
