- Joined
- 22 Sep 2006
- Messages
- 5
- Reaction score
- 0
- Country
Changing the shower has produced this problem. The shower is a hot/cold feed power shower. The hot water is fed from a tank in the downstairs kitchen. This is heated from the Vokera ch boiler in the same room. The cold water feed is from the header tank in the loft. Today I shut off the water feeds to the shower pipes and after a small soaking from the water lying in the pipes seemed to have the situation under control. I was then able to measure up, for the shower unit to be connected to the electrics and to the tiled wall. In this meantime the kitchen lost it hot water supply! While the water supply to the shower was isolated I opened the only valves I had closed in order to restore the hot water supply to the hot water pipes. I now have hot water in the kitchen and no supply to the upstairs at all! Baffled I am suspecting an air lock but how do I overcome this? Anyone? Thanks in advance
