- Joined
- 19 Apr 2005
- Messages
- 57
- Reaction score
- 1
- Country
History - New conventional boiler installed in March. Non Condensing, non combi. Worcester bosch.
Cold water tank in loft with expansion tank to fill central heating. hot water tank also in bedroom above boiler (which is in the kitched)
System only used lightly in summer for hot water, a little air.
Recently added a heated towel rail (complete system drain), and now using for Central heating and hot water a lot due to cold weather.
I am getting a lot of air in 2 radiators nearest the hot water tank, which I am bleeding every 2-3 days. (by a lot I mean top third / half of rad is air if you leave it for a week or so). Can occasionly hear air moving around downstairs rads but I assume it collects in the upstairs ones as no air found on weekly basis in downstairs rads.
The expansion tank ball cock is working OK, and as far as I can tell topping up the central heating. there is water in it etc.
Questions:
1) Is this normal and will it settle after more bleeding?
2) Can't tell if cause is new boiler install (done by corgi registered people) or the newer heated towell rail.
3) What can I do?
Thanks in advance. If I've missed some critical piece of info please advise.
ta
Mark
Questions:
3) What can I do?
ta
Mark
