Loud bangs and surges in system
29 Feb 2004
Hi all. Hope you can help.
I have an open system with a top-up tank in the loft.
Every hour or so when the heating/water is on there is a surge and loud banging. Hot water surges up the overflow into the top-up tank and splashes everywhere.
I have tried slowing down the pump and also extending the overflow pipe to make it higher but it still happens.
Any ideas?
More info please - one or two motorised valves, etc? And what's the ******* boiler?!!!!
Boiler: Baxi WM51/3RS
Pump: 1 Grundfos pump
Separate Sunvic control panel and thermostat.
There is a motorised Sunvic Unishare valve which diverts the flow of water to either water or heating systems (or both).
1 Header tank for the hot water
2 Expansion tank for the Central heating
3 Air separator (if fitted)
4 Pump
5 Motorised valve
6 Indirect Cylinder
7 Boiler
8 & 9 Heating Flow & Return
Except it hasn't got an air separator
You boiler Temperature is set too high, or maybe your thermostat has failed
