Hi All
Have run into an issue with heating at not the best time of the year. A few nights ago at 2am, a loud grinding/buzzing type sound was coming from the cabinet where the water tank, central heating pump and motorised valve etc are located.
This noise eventually went away however the next morning i found the central heating would not work. The (wireless) thermostat downstairs is fine, the receiver for it (located upstairs) is also fine. There is a LED light lit green on the receiver showing the heating is on but the all the radiators are completely cold.
Having spoken to a tech, suspicions are pointing to the central heating pump being faulty. There is no noise coming from the pump at all, it is completely silent, even when the lever on the pump is switched between the 3 settings.
The pump is a Grundfos UPS 15-50. The pump is hot when touched, not scorching but quite warm but as i say, no noise coming from it and the fact that loud noises where heard before the heating went down is what leads us to believe it may be that.
Just curious if anyone else has any thoughts.
Note, the heating has been working fine for many years now, whatever has happened is suddenly, no changes were made or tinkered with prior to it.
Let me know if you need anymore details. Thank you.
