Hi all,
My Worcester Bosch Greenstar 24i combi boiler has recently started to make a very loud buzzing / drone noise, usually within about 5 minutes to 1 hour after the heating has turned on.
The problem only seems to happen when calling for heating, it has never happened when using hot water (e.g. while taking a long shower). After the buzzing starts, turning the heating off from my Tado thermostat gets rid of the noise. But next time you switch it on the problem will eventually reoccur.
Boiler was last serviced in April 2023 and I have checked the pressure is ok (slightly above 1.5 bar when heating is on)
I have a video for reference so you can hear the sound: https://drive.google.com/file/d/1eaYMpi4KvBTgPrV24SmqtO8vr5RFDqJo/preview
Has anyone had a similar problem? Or any experts able to suggest which part might be at fault here?
Thanks in advance.
Thanks in advance.
