Hello,
The blinding flash under my ceramic top happened with 2 halogen hobs lit just as I turned on the top oven. It destroyed the MCB in consumer unit. It turns out that the MCB being only 16A wasn't big enough for a 10KW Electrolux ECK6046W cooker anyway, and I've replaced it with a 20A breaker having done the sparky's diversity calc. But the problem with the cooker remains this: Neither oven works, but the 4 hobs and grill do work. The bottom oven is completely dead, no fan/light/heat, and the top oven causes the flash when the heat is turned on, yet the light and fan work.
I took the back panel off the cooker and there is a big burn mark on the inside of the rear panel and black charring on lots of cables, though none of the cables are actually damaged.
I've inspeced the element in the bottom oven and it appears to be fine and with a multimeter across it's terminals it has a resistance of about 250 Ohms.
I slid out the element for the top oven (not fan assisted) and it looks fine too and also has a resistance, slightly lower than the large bottom oven element.
The elements for the grill are fine too, as expected because it works still.
So can anyone take a pot-shot at what might be going on with my cooker? I'm guessing the bright electrical flash is the result of a short somewhere, backed-up by the burn marks round the back on the inside, but I can't see anything that's gone wrong so don't know now what to do troubleshoot. The cooker is only 4 years old. Thanks. Nathan.
