I have a 4 year old Vaillant EcoTec 428 system boiler which has been showing an F23 error code which is apparently down to a high differential between flow and return temperatures. It is a large 4 bed house with 16 rads.
I had a plumber in who changed the pump on the system, but he said that the return pipe at the boiler was still cool and he thought that maybe there is some restriction in the piping. There are no valves that could be closed causing a restriction and all of the radiators are getting hot. It is just that that HW isn’t flowing properly back to the boiler.
After the pump was changed the boiler ran ok for 36 hours and then I got the F23 fault code again. As the boiler is still under warranty I got a Vaillant engineer in. He checked the boiler and said that it was all ok, including the heat exchanger. He also drained some water from the system and checked the Magnaclean and said that it was all clean. I had a powerflush 2 years ago. The Vaillant engineer checked the flow and return temparatures and although the flow was 65-70 degs, the return was only coming back at about 30 or so. The fault comes up if the differential is greater than 35 degs. He also thought that maybe there was some “restriction” in the return somewhere. The F23 fault has reappeared a couple of times since his visit, but I have been able to restart the boiler each time.
My question is, how can I find out if there really is a restriction somewhere and how can I identify where it is? I had the powerflush 2 years ago and Vaillant say the system seems clean, so I’m not sure that another £750 powerflush is going to do anything to fix the problem.
