Low Flow Rate from Hot Water Tank
24 Sep 2012
London
Hi
I'm just having a new bathroom install and wanted to try and increase the Hot Water Flow rate.
I have replaced the Steel piping from the Hot Water Tank to the Bath with Plastic 22mm pipe but this has not improved the flow, the only pipe I havn't replaced is the Pipe to the Header tank which appears to be 15mm would this slow my flow rate ?
Any advice would be appreciated.
Yes the 15mm pipe will restrict the flow, change it to 22 mm and your flow rate wil improve.
