Hi
Sorry if a similar question has been posted before.
I have a Mira Essentials 10.8 electric shower which has been ok for the past year or so. Recently in order to get a decent temperature the cold/hot dial has to be at its maximum setting with the low/med/high dial on high at the expense of any decent output flow (pressure).
I experimented yesterday to see if there was any discernable difference (temperature wise)if I turned the low/med/high dial down to med and then low. On low the shower went cold as is expected, but on med the shower came up to the same temperature as the high setting. Which makes me think that the high setting is not working correctly. Is there a microswitch that activates for each setting? and will it be possible to replace it if this is the culprit.
Thanks for any advice
Ian.
Ian.
