I have been trying different flow temperatures and have found the following:
With flow temperatures of about 45 degrees to 60 degrees, the boiler switches on at the right time in the evening and starts to warm up, the flow temperature rises to what I have set (55 degrees) and I can hear the boiler lowering the output (modulation?) then the boiler switches off. The house has still not reached the desired temperature. After around 5 minutes the boiler comes back on and cycles until the house has reached the temperature.
With a flow temperature of 75 degrees, the boiler comes on and stays on until the house has reached the desired temperature the house warms up quicker which is what I would expect.
Do you think it is better to leave the flow temperature at 75 degrees?
Thanks in advance!
Thanks in advance!
