Hi everyone. This is my first try at getting advice about a problem I have. Please tell me if more or clearer information is required. I would appreciate any responses.
Ok. I am flat caring at the moment and the flat I am in has a very low hot water pressure to all hot water outlets. The CH works ok. The cold water feed to the bathroom is ok and is fed from a storage tank above the shower. The water flow would take a long time to fill a sink! but it does get hot. I think it is an open vented system.
The shower is fed from an automatic shower pump that only kicks in if you start the shower with the shower head low (near to the tray).
The boiler is a Halstead Best 40db (gas fed) with an additional Halstead system pod attached (houses the CH pump and pressure vessel). I have a pressure reading, on the front of the boiler of 1.7BAR and I think that is what it should approx be.
(sales speil - wall mounted, fan assisted balanced flue natural gas boiler incorporating a cast iron heat exchanger. The appliance incorporates automatic direct burner ignition and electronic temperature control.)
I do not know the age of the system but it all looks fairly new (less than 3 years?) and as I have just moved in, I do not know whether this has been a long term issue.
I have checked all stop cocks (isolating valves) to ensure they are fully on.
Min boiler flow rate 15.27 gals pm / Water capacity 3L
Any checks I can do? what is the purpose of the Red pressure vessel in the boiler?
Thanks in advance...
