Hi guys - experiencing a multitude of problems at the moment. Appologies if this is too long and I'll excuse those that can't be bothered to read it all.
About 18 months ago we had a Thermostatic Power Shower fitted and a 2bar pump. There was no shower before. Pump was installed by a plumber - taking cold from the attic - and hot water from the cylinder (obviously). Everything fine for 12 months.
After 12 months and one day - the pump developed a leak on the hot side of the pump. After arguing with the pump vendor and retail outlet - I bought a Salamander 1.5bar pump, and fitted.
However - since then - things having not been going right.
[1] Hot water pressure downstairs is getting lower as time goes on. At the moment - its taking 20 seconds to get 1Litre of water out of the tap.
[2] The shower is "pulsing", varying the speed of the water coming out of the head, and also the temperature. This only happens when you demand a certain temp of water (ie, all hot - OK, all cold OK, in the middle, not ok).
[1] suggests a blockage - as it got worse and was not an immeadiate change, but one over time. Reasonable?
[2] I'm stumped on -as the only thing I changed was the pump (was easy - or so I thought! lol). Any clues?
Maybe the two are related?
Look forward to you replies, and a nice warm shower again
