- Joined
- 9 Jun 2009
- Messages
- 25
- Reaction score
- 0
- Country
Live in an maisonette (all electric heating and water etc. The hot water tank is upstairs, an Albion Direct Combination Tank with (x2) 3kw heating elements on the side, one above the other.
Have always had bad hot water pressure, so much that with the bath filling the hot water soon slows to nothing with gurgling and other noises.
On the tank low down is a release valve (i assume) if so would could i open this to bleed ?
Or is it somewhere else i should be looking to bleed.
All pipe valve taps are open so greatest water presuure can pass through.
I would prefer to like to do any repair when the water in the tank is cold. Cold rather risk of scalding hot water, or i could heat at a lower temprature, by adjusting the heating element rod temprature adjusters.
