Low hot water pressure
16 Oct 2006
Manchester
Hope you can help!
The water pressure in our hot taps and shower has suddenly decreased (the shower was dribbling cold water this morning), whereas the pressure in the cold taps seems fine. We have checked the system pressure on our boiler (Jaguar combi) which seems ok (1.1). Is there anything else we can check before getting a professional in?
If your cold taps are OK then there isn't much else you can do. The problem could just be a blocked inlet filter (if there is one) or a blocked secondary heat exchanger, but I would have expected a steadily degrading hot water supply to precede the dribble that you describe.
