Hi
I have just fitted a watermill Wasp 50 power shower pump. The cold water is working well but the hot water starts ok and the quickly fades. The cold water tank is about two meters above the pump the top of the hot water tank is about 1 meter above the pump. The hot water tank holds 96 ltrs. The supply to the cold water tank is well fed and not mains. Can anyone suggest a way that I can sort this problem out.
Many thanks
George
Many thanks
George
