I hope to install a ground floor loo with the outlet coming out throutgh the wall some 2.5m from an existing plastic soilpipe.
1. is there a problem with a horizontal (fall 18mm/m) soil pipe so close to the ground level.
2. can a branch fitting be inserted into a vert soil pipe without dismantling the sections above? Is there a fitting/collar that can be slipped up/down the pipe to join the bottom of the branch to the pipe below?
