I've got a problem with my bathroom shower in that the flow rate is not high enough. The shower is a head connected via a hose from the bath mixer taps.
With the shower head below the bath taps it is fine but when you raise it 1.8m onto the rail the flow drops considerably. If you use just hot it is fine, just cold and the flow rate is terrible. What this means is that the shower becomes too hot to stand underneath as it is virtually all hot water.
The heating is provided by a Worcester 24cdi combi boiler and has 22m pipes at the bath taps end, cannot see the start as they are buried in walls. My house is a top(4th) floor ex-council flat.
As the flow looks ok I presume it is a pressure problem. I don't know how the cold feed gets into the building, I don't think it is a tank on the roof. Can anyone suggest a way to remedy things such as a pump or something? Thanks
