Low Pitch Roof Ventilation
22 Aug 2006
Carmarthenshire
I am about to lay underlay on a new 17.5 deg pitched single storey lean to extension on my house.
The roof is a wet roof with vented soffit boards, for ventilation can I take the underlay/ felt up to the ridge and leave a 5mm gap for ventilation, or do i have to take the underlay up the vertical wall to sit under the flashing and then fit vent tiles?
_____________________________
lynda, moderator
your title has been edited, see forum rule 5
You can do either.
If you want to vent it at the wall abutment, then you need propriatary abutment ventilation strips - these sit under the lead.
Or just use a breathable felt
