I have a Puma 80e that has been giving me intermittent problems for some time. Here's a short history of my boiler problem.
The system is about 8 years old and it has give me good service despite failing in the depths of winter. There's no evidence of Global warming in our house
The problem
After having the central heating on for about 12hrs constant the reading on the pressure gauge drops to about 1.0 bar so the Low Pressure LED comes on and H/W and C.H ceases. I re-pressurize the system, but that doesn't correct the fault and the LED stays on.
There is a tiny drip on the diverter valve, but hasn't affected the performance over the last 4/5 months.
This same problem occured in Oct 2004 so I studied the Installation & Service Manual fault chart and it stated that if the problem persisted after re-pressurizing, replace the Water Pressure switch with a new one. This I done; No joy
Thinking that it could be the Modulation Control Board giving a false reading I tapped the the PL-1 connector (top left of board) with an insulated driver and I saw a tiny spark behind one of its terminals, the Mains & Low Pressure LED's then went out. I removed the board and resoldered two cracked joints and replaced it. Still no hot water or heat
This same problem has happened in the past and has baffled a competent Central Heating engineer, but for some reason the system has righted itself a day or so later. The Low Press. LED has gone out and everything starts up. Plenty of H/W and C.H. works just fine.
I hope someone can help, I don't want to call in a plumber because I just cannot afford his charges. If anyone can suggest a quick fix to tide me over 'til spring I'd be really grateful. I can post a pic if requested
All help appreciated,
Tony
The problem
Tony
