Hi guys, was hoping for some expert advice. Got called out today by a mate after an electrician appears to have bodged a job up.
The sparky decided to fit a Triton Madrid 2 electric shower on the third floor of the flat. He tee'd off from the cold pipe going to the basin. Ran new wiring through the loft and connected an electric shower.
However when you turn on the shower, there is no pressure, the water dribbles out and does not get hot. Surprisingly, he changed the shower 3 times assuming fault was with shower, and each time they get the exact same problem.
They also have a shower mixer bath tap, and the pressure there is also very low, the water just dribbles out. There is also very little pressure to the basin taps or from the ballvalve from the toilet cistern as it fills. Ive had a look around the flat and I can't figure out how its been set up.
It has a vaillant boiler turbomax plus 824e, but it also has a very large cold water storage cistern in the kitchen, lietrally the size of 3 large cisterns joined together. I have attached pictures to this post. However there is no hot water cylinder, and no feed and expansion tank.
However due to the pressure being so low, i'm assuming its not a cambi running of the mains but some kind of open vented system?
Does anyone have any idea what could be the problem? and what options they may have so they can have a properly functioning shower? any help would be much apprciated.
