low pressure on Vokera Mynute 14e
29 Nov 2005
I have moved to a house with a fairly new Vokera Mynute 14e.
However, it has pressure almost down to 0, and sometimes a red light starts blinking on the left, and it stops heating.
I think I have to increase the pressure (probably by topping up?), but having no manual I have no idea how to do this.
Any help would be appreciated
Thanks!
on the pipework below the boiler is the filling loop a chrome flexible pipe with a valve on one end turn the valve slightly until you can hear water entering the boiler when the pressure is up to 1.5 bar turn the valve off again.sometimes the loop is removed and caps put on the ends of the pipes but it should be still there and just needs putting back on
thanks for your reply.
Yes, I found the pipe below the boiler. However, it doesn't have any loop and it has a cap put on the end.
Can I just open this cap (will water come out of here? do I need to turn off from the mains?)? I guess I can get a filling loop, and connect it to this pipe, and fill it with ordinary water, right?
