Hi all,
I have recently moved into a Victorian Property and am experiencing some low pressure / reduced flow to the electric shower. The shower works perfectly well in normal operation, but as soon as kitchen tap / washing machine is switched on the shower becomes a trickle.
Some facts about install to answer some questions you may have.
Shower is fed from the rising main and is Triton brand. Kitchen Tap & Washing Machine are both fed from the main. Cisterns and Bathroom Taps are fed from header tank in loft. I have checked and incoming tap is fully opened. Shower head has been cleaned and inlet valve to shower has been cleaned / checked also. Diameter of pipe to shower is 15mm plastic.
I must add that pressure in general especially to the hose pipe is not as strong as to previous properties.
Having read some previous posts, many have advised against a shower pump to electric showers, citing that they are not needed, but in my circumstances do you think this would help ? Alternatively can anyone suggest any solution ?
Apologies for long post but thought it best to provide as much detail as possible.
