- Joined
- 9 Aug 2007
- Messages
- 7
- Reaction score
- 0
- Country
I recently had central heating, boiler and electric shower installed. There is also a new water feed from the meter outside. The feed into the house is 32mm which reduces down to 22 mm inside and then further reduces to 15 mm at the first spur point of the feed.
The pressure at the shower is not great and the low presure light is usually on (with no other water in use). The shower is the last item on a 15 mm feed pipe that is connected to the following:
Boiler, kitchen sink, washing machine, bathroom sink, toliet, bath and then shower.
My question is would the shower performance and pressure be improved if it was fed directly on its own pipe from the 22 mm feed?
Also would it be better to use 22 mm as far as possible before reducing to 15mm to connect to the shower?
