Hi all,
I've just installed a new sink in the kitchen. To do so, I obviously needed to turn the main stop cock (in the street) off. I've now turned it back on and the sink taps work fine - bags of pressure.
However, last night when filling up the bath, the flow of cold water stopped. I got up into the loft, and found the cold water tank had run dry, with the nozzle of the ball valve barely trickling.
My thoughts/findings so far:
1. Air lock - My first thought, but surely if this was the problem, as soon as the ball valve opened, the high mains pressure would force the air out no probs?
2. Knackered ball valve - Doubt it. The header tank takes a feed off the same pipe as the cold water tank. When I push the ball down, it suffers from the same problem - very low pressure. It's almost inconceivable that both the ball valves would have gone simultaneously, isn't it?
3. Crud in the pipes - Very unlikely that there'd be a big enough build up to impede mains pressure - surely?
Any ideas? I'm hoping I'm missing something very simple!
Many thanks in advance,
Rob
Rob
