low voltage ceiling lights - a quick check...
18 May 2007
Argyll
Hi there. I've just moved into a house which is riddled with cheap 20W low voltage ceiling lights. One bank of five (in the kitchen) has now completely failed.
Before I indulge in a spot of post Christmas loft beam balancing, can I just check that everyone agrees a blown transformer to be the likely problem...?
Thanks.
If they all failed together, and there is voltage at the switch, its likely to be transformer failure or a loose connection near the transformer.
Unfortunately the best way to find out is to get in the space above it!
You will need to do some investigation, you cannot expect a diagnosis of your fault when it is impossible to say, as we are remote of your problem.
By low voltage! can I assume you mean extra low voltage (12V in your case) lamps?
Firstly you must confirm this, then check for voltage at the 230V primary side of the transformer(s), using an approved voltage indicator.
If voltage is there and continuity can be found at all the connection at the secondary side(isolate before testing for that). Then the likely problem is the transformers.
If there is no voltage at primary side, you would then be looking for continuity of the conductors at the supply side.
If it's 230V, without transformers then again you would need to test for voltage and continuity.
Also check for fused connections(switch has not been opened and/or fuse blown)
