Hi I was called to a fault today were the tenant of the property had 3 brand new low voltage lights (bnq specials) on the under side of the face board of the porch the tenant had tried fitting them himself (never a good thing) and they surprisingly were wired correctly but to the point I checked the polarity which was correct, i visually checked all the cables no damage / compression failures etc but the lamps just would not light so I presumed either faulty bulbs or transformer so i done a voltage check on either side off the tranny for 240 n 12v so on when i noticed i was getting no voltage on the 12v side (figures) but thn when i tested the 240 side i was getting 400v which kinder threw me a bit is this ok ive never come across this before on a domestic lighting cct before? so then i replaced the bulbs and tranny just to check and when I powered up the tranny made a wierd noise an went dead instantly burnt out but no burnt out smell or heat damage, so again to the point would the 400 v destroy the tranny so quick an how am I getting 400v on a 230v tnc-s supply?
Any thoughts or info would help on the matter as I'm looking to be enlightened on it.
Cheers.
Cheers.
