Hi everyone,
I decided to service my own alarm following some internet based instructions, and a crib sheet left from an engineer who previously serviced the system 18 months ago.
Whilst the alarm appears to be working perfectly, I bought a multimeter to test the battery and mains supply and noticed that I have 14.5V AC across the neutral and earth connections of the incoming mains cable? I think the reading recorded by the engineer 18 months ago was 0.3V or 0.8V AC but he has signed the paperwork stating everything was OK.
The local electrical wholesaler said I shouldn't be getting any reading and leant me another multimeter to confirm the reading - which also showed 14.5 V AC.
I bought a plug in socket tester in case any wiring was crossed but all readings are normal for every socket in the house. I have not had any electrical work done in my home for about 4 years?
Anyone any ideas what could be causing this reading? I would have thought that the reading would be 230-250V if the was a short or crossed wires on my mains circuit. I don't think it is to do with the alarm which runs on about 13.5 v DC.
l'm a bit concerned that an electrician will charge a fortune if he says he needs to check all my mains wiring. I feel I am fairly competent and would like to try and trace the fault myself given some informed advice before resorting to an electrician.
All comments and advice welcome!
