Hello
I have some trouble with some low voltage halogens.
Originally, I had a LV dimmer controlling some kitchen lights.
One gang of the dimmer controlled some under cupboard lights via 1 transformer. The other gang controlled the ceiling lights via 2 transformers.
The transformers were dimmer capable, one of them was these, the others were lower power ones so as not to exceed the dimmer rating.
Anyway, this setup worked fine for about a year with no trouble. Then the dimmer started playing up and lights would turn on / off on their own (the dimmer was touch sensitive - not push button). Then one set of lights stopped working.
I figured the dimmer had probably messed up the transformer by switching on and off too much, so I replaced the dimmer with a normal 2 gang on/off switch. All was fine. But since then the different sets of lights go out randomly. The transformers are getting power, but are not outputing anything (0V).
My question is, what do you think has caused this? Do you think the faulty dimmer could have weakened the transformers to the point they randomly fail. I don't want to get replacement transformers if the same is to happen again.
Any thoughts/help much appreciated!
