flameport said:Extra low voltage lamps (12v) will provide more light per watt than low voltage lamps (230v). Therefore a 12v, 50w lamp will be brighter than a 230v, 50w lamp.
However both types are grossly inefficient, and do a poor job of lighting a room.
handysquad said:LV lamps tend to last a bit longer; MV lamps seem to blow quite easily (not sure if they just react worse to vibration?).
One manufacture has produced a quartz halogen lamp with some sort of filter which converts the infra-red light to useful light but it still does not fall into the 40 lumens per watt so is still not classed as energy saving. Also only available as extra low voltage.flameport said:However both types are grossly inefficient, and do a poor job of lighting a room.
Quite correct. Most of their 'light' output is still infra-red. To get the peak of the spectrum up into the visible range, you would need to run the filament at 6000K. Needless to say, no such filament exists. The future of domestic lighting probably lies with the much more efficient LED in which electrons generate light directly as they cross the energy gap in a semiconductor.
What is a MV lamp? I would think a LV lamp refers to Low Voltage i.e. 230v and these will "be longer and thinner than one in an equal powered" EVL lamp.handysquad said:LV lamps tend to last a bit longer; MV lamps seem to blow quite easily (not sure if they just react worse to vibration?).
The filament in an 'MV' lamp must be longer and thinner than one in an equal powered 'LV' lamp. Ohm's law says so. This will inevitably make them more fragile.
I said:Needless to say, no such filament exists.
