Low water pressure/no water at all from bleed valve
24 May 2007
Leicestershire
Can anyone explain this? I tried bleeding a cold rad this morning (expecting there to be air in the system) but when I opened the bleed valve only a trickle of water came out (no air). So I closed the lockshield valve expecting the water pressure to increase, but instead the water stopped completely! However, when I closed the TRV and opened the lockshield valve, water starts coming out of the bleed valve!
This is an upstairs rad near the airing cupboard/pump and in the past has always heated up quickly along with the other upstairs rads. Also, I had a new pump fitted a few months ago so I know that's ok.
I also have another downstairs rad that has stopped working for no reason at all. Could this be connected to the problem upstairs?
It's a microbore system by the way.
Any clues anyone? Cheers.
Perhaps when the pump was changed crud entered the system from the f&e tank and is blocking the flow manifold to the rads.
a radiator doesn't stop working for no reason. there will be a reason....see above post
from what you have said id check the trv isn't jammed in the close position before jumping in
