Good afternoon.
I have a holiday caravan that has a low amapage supply. It's a caravan park that has the power supply to a box connected to the caravan from a heavy duty ringmain that supplies 6 vans. The main supply to this van is only a 16amp breaker. I want to get some more water pressure to the shower and sinks, the lpg gas boiler cannot cope with giving me the pressure at the temperature needed.
I have therefore decieded to fit a direct water cylinder with an expansion tank with a 170 Ltr tank with imerssion heater. I am not concerned how long it will take to heat the water as it is not used in large quantities but need to restrict the ampage draw so as not to overload the circuit if I have the kettle, lights or washing machine on. Do they make an imerssion heater rated at 1KW or below and am I thinking on the correct lines that this is the answer?
Thanks in advance for your assitants.
