I want to lower my first floor ceiling to get extra height in the loft but how would I suitably tie the new floor to the roof structure to prevent the roof spreading.
Why do you need extra height? what is the current height in both areas?
Do you have any example pictures of this done. Just wanted to see what it would look like.You may also need to form bulkheads around the tops of the first floor windows if your new floor is to be below the tops.
Is that height from the top of the existing ceiling joists to the underside of the existing ridge? What height is your first floor floor - ceiling?I want to convert my loft into an office/bedroom. At the moment height is about 1.8m.
If you cut out those joists, your house will fall down. The roof will push the walls apart.
like this
https://metro.co.uk/2016/06/08/dram...se-660000-collapse-during-renovation-5932499/
Observe the work done by the "builders" prior to the collapse:
