I have just received a set of timber windows for my mums house and the lower piece of beading used to fix the glass in is deeper (front to back) than the other three pieces by about 9 mm. The window company says that this is to stop water seeping back under the beading and thus compromising the double glazing unit. Is this standard practice or just wishful thinking? The underside of the beading does not have a drip grove in as on the underside of a sill. Would I be best to route a grove in this piece or to trim it to the same depth as the other pieces thus making the front of the beading flush with the frame. That way I can paint over the joint and see if there are any gaps.
Any advice gratefully received.
Steve
Steve
