Lower Height dishwasher
17 Mar 2008
Yorkshire
I`m looking for a dishwasher thats around 1.5cm lower than the standard 85cm height, can anyone recommend one, thats if there is any that are slightly lower than standard height
On Bosch and similar, you can remove the worktop. It is about 35mm thick.
mine is then rolled under a worktop, so no. The door in the front contains sound deadening packing. You could flop some felt on the top if you wanted to.
I took the top off mine so wheels fitted under it.
