when i have HW on by itself, the boiler heats the water up to 72 degrees and the HW cylinder heats up to full temp in about 50-60 mins. If the CH is on by itself, the rads heat up to 72 degrees. However, when CH and HW are on together, the boiler only heats the water up to 62 degrees and so the HW takes about 20 mins longer to heat up to full.
is this a faulty stat, or purely because the boiler is having to heat up a larger volume of water? if this was the case i would have thought it would still heat up to 72 degrees, but it would take longer to achieve 72.
The system is a Honeywell C plan
Glow worm space saver 40Br
