After 5 years my house is nearly in order. the last remaining task is to get the plasterers in to skim the walls in the hall and landing.
Unfortuntely the landing ceiling is a mess (sagging) so I'm looking at fitting studwork to make a lowerered ceiling.
It's an old terraced house with high ceilings so losing a bit of ceiling height isn't a problem.
The area is approximately 1.50m wide by 4m long and will have a generous gap for the loft hatch at one end.
Two sides of the supporting framework (one long, one short) will be attached to (non load bearing) stud walls, the third (long) to brickwork (the party wall with my neighbour), the fourth (not sure, probably brick)
What size timber should I be using for the studwork? I've looked at cls timber and the 38 x 63 looks too insubstantial. What about 38 x 90mm cls or would 40(?) x 70mm scant do?
Also, what would be the most sensible way to position the studs. Should I just fit the outside perimeter then equally spaced cross pieces spanning the width (i.e approx 1.50m span)?
